tonneau pad removal
Old Nov 1, 2009 | 05:07 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
tonneau pad removal
I'm restoring a vert and can't figure out how the pad is attached to the tonneau. I don't see any screws or bolt. I just don't want to break the pad cover.
Old Nov 1, 2009 | 06:31 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
Re: tonneau pad removal
I have been trying to talk myself into removing mine also. They are glued down.
Old Nov 3, 2009 | 09:52 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Yup, glued. Start on one edge and work your way across. It's a zig-zag pattern so once you get started it comes off pretty easy.
Kevin D.
Old Nov 4, 2009 | 02:18 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
it's not that bad even if it breaks it is just fiberglass just get some resin and reglass it.
Old Nov 4, 2009 | 03:52 PM
wvabreeze's Avatar
While on this subject. Mine needs the vinyl covering replaced. Did you all remove the old vinyl or just cover over top of it? Is the vinyl hard to get off?
Old Mar 7, 2011 | 06:41 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
the ends of mine are torn up a bit and i need to fix or replace it. anyone try this yet?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
