Firebird map pocket in Camaro
Old Nov 30, 2020 | 01:03 AM
Swapper's Avatar
whats up guys. just wanted to show something i did recently and have always wanted to do on my previous Camaros. i had a couple different firebird/ trans am map pockets from my old junkyardin days but happen to have one tan one that didnt have any logos stamped on it. so i dyed it black with fabric/ dye paint from autozone. I made a template out of some cardboard, transfered the the mounting points from the map pocket to the cardboard. then i put it on the dash where i wanted it and drilled the 6 holes into my dash and since the pocket just uses those christmas tree push pin things i just pressed them into the holes on the dash. i also decided to transfer the badge from my dash onto the pocket. the badge might get changed if i get my new custom emblems but i kinda like the cleanliness of the original badge. im thinking of tucking a magnet inside the flap of the pocket and putting a screw or piece of metal under the top of the dash so it can hold the flap up if needed.
Old Dec 2, 2020 | 01:47 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Firebird map pocket in Camaro
Surprised that I don't see this modification more often. I'm guessing it's because so many of the pockets have some type of Pontiac/Firebird logo on them. IMO: it looks pretty cool !
Old Dec 2, 2020 | 02:43 PM
Swapper's Avatar
thanx. yeah most of them have some kinda of firebird/ trans am logo on them.
Old Dec 2, 2020 | 04:15 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I like that. Takes up that large bare space also.
Old Dec 2, 2020 | 09:12 PM
Swapper's Avatar
yeah it always kinda bugged me having that big open. if there wasnt a a/c unit back there id cut it open and make it more of a glovebox.
Old Aug 30, 2023 | 06:45 PM
dsmith124's Avatar
Car: 1990 RS Convertible
Engine: 305 TBI
Isn't there some electronics behind the dash that you might drill into?
Old Sep 3, 2023 | 10:26 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Mostly the Hvac box, but there is a cruise control black box thing about between the center vents/map pocket. That one is mounted up against the dash.
Classic used to sell a "glove box" you could mount externally in that spot.
okay
Jul 22, 2020 09:09 PM
ROONEY
Oct 15, 2018 04:54 PM
CamaroKarl
Interior Parts Wanted
Sep 23, 2018 01:28 PM
3rdgenparts
Sep 3, 2016 09:02 AM
Psycho_91Camaro
Feb 19, 2008 02:25 AM
