Fresh air vent replacement?
Old Jan 24, 2021 | 01:57 PM
Bernie Dyck's Avatar
Car: 1989 Camaro RS
Engine: 5.3 lm7
Axle/Gears: 4:10
Hey guys, new to the forum so hopefully this Is the right spot for this question. I've got a water leak coming through my fresh air vent on the drivers side. The "Flange" or whatever one would call it is broken and so the gaskets no longer sealing so anytime it rains or I wash the car I've got a big puddle in the car. My question is where does one buy a new fresh air vent? I've searched everywhere and I've only managed to find one on ebay but unfortunately it's the passenger side vent and I'm not sure if this will fit. Any advice here is much appreciated as I'm out of options it seems. If needed I can post a pic or 2 to make things easier.
Old Jan 26, 2021 | 09:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Fresh air vent replacement?
New, probably nowhere unfortunately. Not really a high failure rate part. Best bet is to find a good original and/or replace/make a new seal.
Old Jan 26, 2021 | 11:48 PM
Car: 1989 Camaro RS
Engine: 5.3 lm7
Axle/Gears: 4:10
*update*
​​​​​​I've come to find this part is nearly impossible to find. Luckily I found a part out car on ebay and was able to pick it up at a reasonable price! Good luck to anyone else with this issue 😂
Old Jan 27, 2021 | 01:34 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
As far as I know, these fresh air vents are only present on cars without A/C. That makes it even more rare and hard to find. Your best bet would be to repair your vent with a plastic welder and cut a new seal for it.
Old Jan 28, 2021 | 01:18 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Are you sure it's the vent and not a rust/rot hole in the cowl ???
Simsalas
Jun 23, 2016 01:54 AM
aletheian
Apr 12, 2007 01:48 AM
*F-BodyFanatic*
Jul 30, 2005 10:37 PM
ksrammstein
Mar 5, 2004 09:21 AM
GTA400SBC
Dec 17, 2002 07:29 AM
