Rear hatch switch
Rear hatch switch
Hi!! Do any of you know if the c4 Corvette hatch switch (the one in the door) is a compatible replacement for an '88 camaro? They look exactly the same to me but want to make sure.
Thank you!!
Thank you!!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Rear hatch switch
I believe the vette version has a pigtail on it. The one i pulled off a 96 is like that. So its not a P&P, but will work. I'm using one for the trunk release. Which basically triggers the solenoind/pulldown motor.
