Clutch pedal removal
Old Feb 1, 2021 | 09:45 PM
CKRacing's Avatar
Car: 1984 Camaro
Hi,
I have an ‘84 Z28 and I’m trying to figure out how to remove the clutch pedal. Anyone know where the rest of the bolts are? I got the master and brake booster removed already but the dash is still in.
Old Feb 1, 2021 | 11:00 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Clutch pedal removal
There's 1 bolt that gets installed by turning it straight up into the body,....... gotta' drop the steering column to find it.
Old Feb 2, 2021 | 12:22 AM
CKRacing's Avatar
Car: 1984 Camaro
Great, I’m also planning on swapping in a tick master since I’m doing a t56 swap. Any ideas on the best way to attach the rod end to the stock third gen pedal?
Old Feb 4, 2021 | 12:34 AM
John in RI's Avatar
I did the T56 swap and used Thirdgen pedals & 4th gen hydraulics,... never played with a "tick" !
Old Feb 4, 2021 | 01:57 PM
CKRacing's Avatar
Car: 1984 Camaro
The tick is basically the same as any fourth gen master just upgraded interals. So what did you do to hook up the master cylinder rod to the third gen pedal?
Old Feb 4, 2021 | 02:05 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I used one of these in my 2nd gen. Just buy the proper diameter clevis pin and weld it in
https://www.mcmaster.com/clevis-pins...e-clevis-pins/
JKelch
Jan 21, 2016 12:56 PM
indy82tx
Oct 28, 2007 12:07 PM
dragonfyre88
May 20, 2003 01:42 PM
