clutch pedal- worn linkage stud
Old Mar 4, 2002 | 12:17 PM
indy82tx's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
I'm converting my 82 from automatic to T5. The clutch/brake assembly I'm using is from an 84 Firebird. The clutch pedal linkage stud is worn (almost half of the original cross section). This is the stud that attaches to the hydraulic clutch master linkage with a clip. The stud is attached (riveted?) to the clutch pedal lever arm. I'm concerned that it will break in the near future. Has anyone found a good way to repair this stud? Is this a common problem that I'll find if I look for another pedal in the junk yards?
Thanks,
Ken
82 Z28, LU5 still alive...
Old Mar 4, 2002 | 04:46 PM
Patrick007's Avatar
I don't exactly know which part you mean. but if I had a stud like that which was worn.. I'd weld metal back in a grind it till it was round again... just my .02
Patrick DeGrosse Jr.
Old Mar 5, 2002 | 07:14 AM
indy82tx's Avatar
Engine: 305 LU5
It's the stud that connects the clutch master actuator to the clutch pedal. The linkage from the master actuator slips over the stud. A clip slides over the end of the stud to keep the linkage from sliding off.
I had thought about welding replacement material back onto the stud and grinding it back to its original dimensions, but assumed the part was heat treated. However, based on how it has worn, it may not be heat treated.
Old Mar 5, 2002 | 09:32 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
If you're talking about the stud that's on the clutch pedal itself, mine wore out like that as well. I just replaced it with a junkyard pedal.
It seems to be lack of lubrication that kills them.
Old Mar 7, 2002 | 03:20 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
It seems to me that it isn't a lack of lubrication but maybe that the little plastic bushing/clip breaks and/or falls out and allows metal to metal wear. Maybe???
anyway, Mine didn't have the problem when I swapped so I didn't notice how the stud was attached. I would assume it's welded on. The easiest route would be to find a replacement pedal out of any manual tranny equipped camaro (4 cylinder, V6, V8).
HTH,
Clem
Old Mar 7, 2002 | 03:21 PM
99Hawk120's Avatar
LOL, mine didn't have a plastic thingy. Then again, neither did the donor pedal I grabbed.
Old Mar 7, 2002 | 04:23 PM
indy82tx's Avatar
Engine: 305 LU5
I've pulled three pedals from junk yard cars. All three were worn beyond use. One afternoon down the drain. The GM parts catalog does NOT show any bushing.
I'd hate for the linkage to break while I'm pulling into my garage. I'm looking at drilling out the stud and replacing it with a shoulder bolt.
Old Oct 28, 2007 | 12:07 PM
ToFastToFurious's Avatar
Re: clutch pedal- worn linkage stud
im looking for the same part, its the rod that connects the clutch master cylinder to the clutch pedal. its just screwed on to the master cylinders rod. if you can find another just unscrew it and screw the new one on. i know this cause mine just snapped, and no parts shops have this thing, anyone know where to find one??
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
