Tilt Steering Pins
Old Mar 23, 2021 | 06:05 PM
stuckinkaos's Avatar
Car: 91 IROC
Engine: 5.8L V8
Transmission: lame automatic :(
Tilt Steering Pins
Dudes,
I haven't been able to find anyone with a solution to rounding out the holes that hold the steering column's tilt contraption in place. I'm talking about the 2 pins that go in level on the left and right side of the steering column. The pins themselves are strong and in good condition, but the tilt steering unit is made of a softer (lead-like) material and like many other Camaros, someone probably used the steering wheel as a handle bar to get out of the car and the left pin's set hole is warped like an oval. It causes play in the steering wheel to the up/down left.
I don't notice it when I drive, but it's failed inspection and I can't get it to pass. Even used ones come with disclaimers that they wobble. Has anyone ever successfully FIXED one of these?
Old Mar 24, 2021 | 07:42 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: Tilt Steering Pins
the fourth post has a lot of links you may want to look through https://www.thirdgen.org/forums/inte...fix-pivot.html
Whoboy580
Mar 4, 2016 07:10 PM
andy625
Sep 2, 2010 07:12 AM
SLAYER6669
Jul 24, 2005 04:16 AM
drdave88
May 5, 2003 10:17 PM
