Anyone swapped a 92 steering wheel for an eddy w/ adapter?
Old Sep 22, 2021 | 07:35 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
Greetings all. I picked up an eddy steering wheel and their adapter from hawks:
https://www.hawksmotorsports.com/bil...rn-cap-for-gm/
Now I see everyone pretty much uses grant wheels, as there's zero install instructions or diagrams or anything I can find on the internet for an Eddy into a '92!
I pulled the 92 wheel off with the bag and all, and now I'm trying to figure out how much should remain. Does the 'coil' thing that was behind the old wheel need to stay? I cannot find the use for it after removing the stock wheel other than to take up space. The adapter definitely wont sit down over that area as its threaded for the fine toothed wheel portion not the wide tooth shaft portion of the column.
Also it looks like my horn wire plastic retainer with the spring is broken, maybe new it had some kind of press down and sideways action to hold it in there, now there's nothing. I don't think I can just leave it wedged in there as I don't think this adapter would put enough pressure on it to keep it in there, or would it?
Any experience greatly appreciated!
Old Nov 13, 2021 | 01:52 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Anyone swapped a 92 steering wheel for an eddy w/ adapter?
remove the air bag coil..just clip the wire. ya can slide the wire out of the bottom if ya like or just leave the wire..
you can get a new Plastic tube for your horn at most auto parts stores Iv seen them and under $4
onebad92
Jun 27, 2013 09:00 PM
lightemup89
May 21, 2004 07:19 PM
RallyRedTexan
Feb 24, 2003 12:47 AM
juxstapo
May 1, 2002 10:22 PM
