Tinting T-tops
Old Jan 30, 2022 | 11:31 PM
haydenb's Avatar
Tinting T-tops
Hi; I'm not 100% sure if this is the right thread for this but I've been thinking about maybe getting the T-tops tinted since they tend to let a bit too much sunlight in sometimes and if I want an open air feeling I'll just take off the tops anyway. Does anybody do this & is this a good solution?
Old Jan 31, 2022 | 12:01 PM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Re: Tinting T-tops
The inserts GM made are rare it seems these days. Hawks makes inserts though. Maybe look into those. I have GM originals, they are in as long as I have the tops in.
Old Jan 31, 2022 | 01:38 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Tinting T-tops
I had mine tinted 5% shortly after I bought the car (new) and have had no issues with them.
Old Jan 31, 2022 | 07:59 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: Tinting T-tops
I dont care for the extra sunlight either so had dark tint put on them and its perfect
Old Feb 1, 2022 | 10:53 AM
Abubaca's Avatar
Re: Tinting T-tops
For what it's worth....the modern ceramic tints that block UV rays make a huge difference in the heat they allow in. I always liked the light from the t tops but not the heat. You can even get a clear UV tint, and it DOES cut the heat quite a bit. Lotsa people doing this on windshields. Anyhow....if it's the heat more so than the light...maybe that's an option.
1701-Z
Jan 25, 2016 09:43 PM
mr396
Mar 11, 2009 07:13 PM
92 Rag
Sep 30, 2004 07:00 PM
