‘88 GTA inner door belt replacement
Old Feb 13, 2022 | 06:23 PM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
I searched but did not find any threads on inner door belt replacement (‘88 GTA) It appears there are plastic stakes that held the original but they are disintegrated. What methods are people using rivets? Screws? Glue? I am concerned the first two may interfere with the install of the door panel.
Old Feb 13, 2022 | 07:32 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: ‘88 GTA inner door belt replacement
Inner door belts?
Old Feb 13, 2022 | 07:35 PM
hessm70's Avatar
Belt weatherstrip inner on door panel upper
Old Feb 14, 2022 | 07:13 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
Those had plastic rivets from the factory, I noticed that when I had mine off recently you would have to probably glue them or plastic rivet as its pretty tight for clearance. Something like a zip tie will not work.
Old Feb 14, 2022 | 07:16 AM
hessm70's Avatar
Yeah I am wondering if aluminum rivets would work. I am a bit concerned about them protruding where the door panel clips over the top causing them not to seat where they need to be. I may just have to try some things. One of mine had a heavy staple in it which would work but I don't have that at my disposal.
Old Feb 14, 2022 | 06:23 PM
Johnny Gun's Avatar
Car: '88 GTA
I see now.
I used 1/4" self-tapping screws and then cut the tips of them off with a Dremel. Next time, I'll use rivets or try using E6000 glue. Stuff works wonders.
Old Feb 15, 2022 | 06:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
when I replaced my weatherstripping 1A sold the window molding with the inner sweep attached .
Old Feb 15, 2022 | 06:59 PM
hessm70's Avatar
My door panel uppers are good and I only need drivers side which is why it was only replacing the weatherstrip/belt.
bensbaby
Nov 12, 2019 07:11 AM
dhirocz
Dec 4, 2013 03:48 PM
Firechicken86
Sep 6, 2012 11:11 PM
michaeloehl
Exterior Parts Wanted
Oct 22, 2008 07:32 PM
ejm
Aug 17, 2005 03:20 PM
