Do t-tops need to come off (an 87 T/A) to replace sagging headliner?
Old Feb 21, 2022 | 03:53 PM
Gen X T/A's Avatar
Car: 1987 Pontiac Firebird Trans Am
Engine: LB9
Transmission: Turbo Hydra-Matic 700R4
Axle/Gears: 2.73 limited slip differential
My glass t-tops have either never been off my 87 T/A or they have not been removed once in the past 30 years. I currently have no leakage issues. My original headliner is beginning to sag in the rear and it ready for replacement. Can an 87 t-top headliner be replaced without taking the t-tops off? To compound the issue I also have the optional overhead console which needs to be removed for other reasons (flashlight battery leaked and I need to clean out the resulting small amount of corrosion). Same question. Can that overhead console be removed with the t-tops remaining in place?
I'd love to take the tops off, but I do not want the leaks, squeaks and rattles ultimately that come with taking those tops on and off. Thanks in advance!
Dan W.
Tempe AZ
Bone stock 1987 Trans Am
Old Feb 21, 2022 | 05:39 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Do t-tops need to come off (an 87 T/A) to replace sagging headliner?
I think it would make it easier to work around imo.
Old Feb 21, 2022 | 06:19 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
No. There's nothing that I can think of that would require the tops to be removed for the headliner repairs.
Old Feb 22, 2022 | 08:22 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the A and C pillar trim must be removed in order to pull out the headliner (in one piece). don't know how that could be done without pulling the t-tops. attachment screws for both are under there.
the overhead console can be slid back from the mounting studs once a couple of screws are removed.
Old Feb 22, 2022 | 09:49 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Got a few close ups over here with the T-Tops off. Don't recall if the front pillar thing that holds the t-top on comes off. If it makes you feel any better, I take mine off everytime I drive it. always have. no leaks, at least when I wash the car. It doesn't get driven in rain. and T-tops are always off when driving, a helluva lot more fun that way! https://www.thirdgen.org/forums/memb...ml#post6327405
Old Feb 22, 2022 | 10:56 AM
naf's Avatar
naf
yep
first pic in post #5 clearly shows the A pillar trim and the top screw that mounts it, which would be obscured were the t-tops installed.
Old Feb 22, 2022 | 06:16 PM
scottmoyer's Avatar
Good call out. I was going from memory and obviously, age is catching up with me. naf is correct. The A and B pillar trim do hold the headliner and need to be removed.
Old Feb 23, 2022 | 07:59 AM
naf's Avatar
naf
my memory was recently refreshed. I pulled the headliner and trim out of my pontiac last weekend to start some rust repair in the t-top channels....
Firm
Jun 30, 2015 09:09 PM
ttopkindaguy
Jan 2, 2013 09:06 PM
TABANDIT
Jul 24, 2006 01:14 PM
Randy82WS7
Mar 21, 2002 09:29 AM
Cityboy
Sep 26, 2001 04:27 PM
