passenger seat to driver seat
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
91 Z28. I want to replace my driver seat because of a tear. Can you swap the side lever & forward tilt lever/**** from a driver seat to a front passenger seat so you can use it on the driver side?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: passenger seat to driver seat
one's I've dealt with would not allow swapping sides for the tilt mechanism controls.
best bet may be to swap the foam and good fabric from one seat to the next. passenger seats are usually an excellent option for 'like-new' foam.
Car: '89 GTA
Engine: ZZ6TPI
The frames are specific to each side, but the foam and covers can be swapped.
Sounds like a plan. Any trick to getting the foam & cover off with out destroying it?
Car: 1986 Iroc-z, 1968 Camaro RS-ss
Engine: 305, 396
Transmission: auto
Should come off very easy. When you go to put the back cover on put a plastic bag over foam first be for pulling cover. this will let it slide over easier. then rip plastic and pull out.
Car: '89 GTA
Engine: ZZ6TPI
You will also need to cut the hog rings to get it apart and then put it back together with new ones. Get a good pair of hog ring pliers.
