Trunk pull-down problems
Old Jul 6, 2022 | 12:42 PM
wmccallum13's Avatar
Car: 1991 Firebird Formula
Engine: LB9
Transmission: Five speed
I have recently been working on my 91 Formula trunk pull down mechanism. At first all I knew was that the trunk latch doesn’t get sucked down by the pull down mechanism. After a little bit of troubleshooting I confirmed that the motor works and the gears are fine. What I’m thinking is the little switch that is triggered by the trunk latch itself isn’t working. The pull down will return to the open state if it is all the way down, but it won’t go into the closed state. So am I right about the latch switch, or could something else be causing my problem?
Old Jul 7, 2022 | 08:27 PM
GEmrsn's Avatar
Car: 89 GTA ASC Convertible
Engine: 5.7's
Axle/Gears: 3:27
Re: Trunk pull-down problems
Mine is doing exactly the opposite... it will close and not come back up (motor gets really hot and drains the battery). Sounds like your pulldown switch is bad and my bottom stop switch is bad. Together we may have a good unit! I'm looking for good used switches. If I find another good pulldown switch I'll let you know.
Old Jul 8, 2022 | 03:38 PM
erik69&85's Avatar
Keep on eye on top-downsolutions.com for parts ...
Old Jul 9, 2022 | 05:04 PM
Engine: LB9
Yeah finding a working latch switch is a real pain, I’ve looked online and most of what I am seeing is the reversing switch.
Old Jul 12, 2022 | 12:12 PM
Engine: LB9
So after taking apart the striker switch and verifying that it is working, my hatch pull down still doesn’t work! At this point I’m really second guessing myself and really have no idea anymore as to what could be causing my problem.
santiclause
May 23, 2016 09:48 PM
V8SC1987
Convertibles
Oct 5, 2015 01:51 PM
TIMMYS89GTA
Convertibles
Oct 16, 2014 11:47 PM
bubbagump2001
Jun 12, 2013 01:18 AM
db73
Jun 21, 2012 06:23 PM
