What size corbeau FX1 seats
Old Aug 28, 2022 | 03:11 PM
Rosco the Iroc's Avatar
Car: '89 IROC, '14 LTZ Burb, '18 H6 Outb
Engine: 355 TPI /w Vortec
Axle/Gears: 9 bolt 3.27
I'm redoing the seats in my '91 Z28. I got the wide FX1's to fit me better but they are too wide for the car. The leg wing is hitting the center console and pushing the adapter sliders toward the outside about an inch.
They say the wide is 24" and reg is 22" Pro is 20" at the front. I don't think I can fit in the pro and would like to go reg.
So the question is- did anyone else put them in if so were they the reg and did they fit?
Old Sep 22, 2022 | 04:26 PM
Re: What size corbeau FX1 seats
Update.
I got one Reg FX1 in and installed the driver's side with their bracket. It fits but..
I'm 5' 11" and my head was in the headliner. Way too high. I took the bottom cushion out and I fit a little better.
Another issue is I'm too close, even with the slider all the way back.
So the seats have 4 mounting "legs" that add about 2" to the seat from the bottom of the shell.
Old Oct 22, 2022 | 08:39 PM
If anyone is following, I took the removable cushions out and I could fit better. The passenger side went in tight and the OEM belt does not sit well, might need to put on a seat belt ext to make them work. The drivers side is going to have a 5 pt.
Old Oct 22, 2022 | 11:32 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
I hear ya on the height issue, I'm almost 6'4 and with my Corbeau A4 seats and my autox helmet I had to remove the tracks AND cut/reweld the brackets or I was either bumping the Ttop glass or poking my noggin out the top of the car.
Agree the non-wides are very narrow, and I'm a skinny guy. so opposite you I add cushions to drive around and remove em when I'm on the track. Overall they are a huge improvement tho.
ace74
Mar 2, 2013 02:25 PM
Gen X Mar0
Jul 15, 2006 11:27 AM
FIRECHICKEN
May 15, 2006 11:03 PM
PaveTim
Sep 22, 2003 03:10 PM
pardonme2711
Jun 10, 2002 11:46 PM
