Hatch pull down stuck down
Old Oct 6, 2022 | 06:54 PM
91Jay's Avatar
I opened the hatch on my 91 camaro and the pull down never went up. So now I can’t close the hatch. Is there a way to manually close it while I wait for a new pull down assembly?
or any thoughts on what it may be?
Old Oct 7, 2022 | 03:27 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
Re: Hatch pull down stuck down
It will shut but you have to slam it real hard to close it. But you have to pray to the gods of 3rd gen heaven that the glass doesn't shatter to pieces. You can try to pull the fuse for the hatch motor and put it back in a few times. Sometimes this works to "kick" the motor with a little voltage peak and it MAY come up again.
Old Oct 7, 2022 | 09:05 AM
91Jay's Avatar
Originally Posted by J.C. Denton;[url=tel:6481751
6481751[/url]]It will shut but you have to slam it real hard to close it. But you have to pray to the gods of 3rd gen heaven that the glass doesn't shatter to pieces. You can try to pull the fuse for the hatch motor and put it back in a few times. Sometimes this works to "kick" the motor with a little voltage peak and it MAY come up again.
thanks!! I got it closed! I closed it gently until it wouldn’t go further and then kinda shoved down and after a few times it latched! Now at least I can drive it while I wait for a new part. Thanks again!!
Old Oct 8, 2022 | 10:15 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
if u open a door a little, the rear hatch will close more easily. No slamming required.
bbsr72
Feb 8, 2025 06:16 PM
T-Ruxx
Mar 5, 2020 02:01 PM
Buggy Disaster
Apr 1, 2012 07:15 PM
