Lower Dash Panel
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Lower Dash Panel
It's there a different between 86 iroc lower dash panel and 90 lower dash panel..My 85 dash is cracked by the defrost button.
Re: Lower Dash Panel
Yes... The 90-92 lower dash is different... The sharp lines are smoothed over with curves... You need an 82-89 dash...
I have both.. an 88 and a 92 so it's pretty clear to me... Very little is the same between those two dashes...
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Dang I can't find a dash my year. I guess i will epoxy glue it with a brace on the back and wrap the dash in leather
Car: 1985 Z28
Engine: 305 LG4
I had cracks elsewhere on mine but used plastic epoxy and fiberglass mesh for support. Holding up fine 13 years later...
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Mine is cracked/broken in two big halves. They're held together with strips of sheet metal i riveted to the dash across the crack. There's 4-5 strips from the center vents down to the corner by the radio bezel.
