1992 RS steering wheel
Old Jan 17, 2023 | 02:39 PM
uncledad's Avatar
Newbie here! I have a 1992 RS 5.0, 5-speed. I'd like to get rid of the airbag steering wheel and if possible install a GEN-2, 4 spoke as seen below. Is this possible? Do I need an adapter? Any help is appreciated. Thanks in advance!
https://www.jegs.com/i/OER/691/45899...SABEgIFIPD_BwE
Old Jan 18, 2023 | 09:11 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Re: 1992 RS steering wheel
I would call JEGs and ask since it's not listed as compatible.
What are you doing with your stock steering wheel and airbag?
Old Jan 20, 2023 | 09:19 AM
uncledad's Avatar
Jegs or anybody else won't really commit to fitment on anything other than what they have listed. That's why I was hoping someone here had done the same swap. One post says an gen 2 wheel worked on a gen 3 firebird? I have a feeling it will work, it would be nice to confirm before forking over a couple hundred bucks. Assuming I change the wheel I'll hold onto the original, the car is really low miles all original so I'd keep the old steering wheel.
Old Jan 20, 2023 | 05:24 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Keep in mind that some states require you to keep the air bag on the car and you won't pass legally if you remove it.
89iroc89
Jan 27, 2012 04:04 PM
