Camaro carpet
Camaro carpet
I started this thread and hit the wrong button, do not know were it went. Anyway is there A big difference between ACC and marylandgp both made in U.S.A.
Re: Camaro carpet
It was on ebay and thats all that was there was marylandgp. said made in U.S.A.
Re: Camaro carpet
Well I just looked again and it is gone. Must have been a scam
Car: 90 Formula / T-tops
Transmission: MD8
Re: Camaro carpet
there seems to be different vendors of the ACC carpet. but it would be interesting to know if there is another repro man out there
Re: Camaro carpet
Does this carpet have the mass backing? Makes a big difference in noise and heat reduction. It's a thick plastic like backing molded in the carpet. What is the cost for the full set, front and back and in the hatch area?
Re: Camaro carpet
it was about one hundred dollars cheaper, but really it was not up long enough to check it out. By the time I posted and went back on ebay the sight was gone. Think it was a scam. To busy to check today. I will look right now.
Re: Camaro carpet
Looks like the name of the place is Newark Auto. It does not have the cargo area carpet but has 20 oz jute backing. 229 dollars for front and back. I figure since it was the we hour
s of the in the morning the could have just been posting their add
Re: Camaro carpet
The price is 209 now for front and back. They have extra mat and adhesive for reasonable prices
Transmission: MD8
Re: Camaro carpet
well by gosh, there may be someone else out there making them, it seems to be missing the toe pad. https://newark-auto.com/collections/...uto-carpet-kit
Re: Camaro carpet
The quality dose not seem to be great. Now upon reading further it appears to been sewn together.
Re: Camaro carpet
In the small print on the web sight it states that it is indeed sewn. Acc will be my choice. Thanks for the feed back.
Re: Camaro carpet
If for some reason you want a non-factory color carpet, you can order from this website:
https://www.stockinteriors.com/
You can buy factory colors too but it may not be as cheap as RockAuto.
Stock interiors also lets you order carpet samples 5 at a time. When you do that they’ll also send you a 5% discount code. I also wasn’t charged sales tax which saved money. Between the code & no sales tax I saved $80 on my order.
Re: Camaro carpet
i was not raised with computers, i keep hitting some button and everything is gone. Thanks for the info. Will get ACC molded and install on a hot summer day after it cooks for awhile
