Bolts/screws
Old Apr 3, 2024 | 12:47 AM
Fuzzy_Socks's Avatar
Bolts/screws
I feel like I have looked absolutely everywhere.
I am in need of the screws to mount the gear box as well as the screws to keep the plate held down above the motor on the trunk pull down mechanism.
Does anyone know the actual measurements? I can find SOME of them in a whole repair kit but not all, and it doesn't tell you the size.
Old Apr 3, 2024 | 07:39 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Bolts/screws
Pics would help
Old Apr 7, 2024 | 04:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Bolts/screws
give me the no. on the drawing
Old May 26, 2024 | 12:07 PM
JA411's Avatar
Re: Bolts/screws
When you bolt it in leave the 3 bolts loose or hand tight. Then close the hatch and let it pull down. Then push down of rear of hatch once it is lined up
secure the 3 bolts. If you just put it in and close if it binds it can break the glass!
Joe
91rsed
May 2, 2018 02:38 AM
W.E.G.
Oct 8, 2017 09:36 AM
Jekyll & Hyde
Oct 26, 2004 11:39 AM
madmanups
Feb 11, 2003 05:06 PM
breathment
Dec 11, 2002 03:35 AM
