how and the heck do i get the FPR off??????
Old Dec 10, 2002 | 05:39 PM
breathment's Avatar
EDIT: ok i just read vaders article again, and i see the screws are TAMPER proof torx screws.. geez i guess they really didn't want anyone getting that thing off!
Old Dec 10, 2002 | 06:22 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you're an animal like me and your local sears craftsman aisles are as lame as mine you can make do as Vader suggests in the article by ounding the tit flat with a hammer and a punch or similar.
Old Dec 10, 2002 | 06:57 PM
breathment's Avatar
haha. well i tried using a punch and hammer to pound the **** down. but i only got 3 where i could insert the torx and get the bolts out. the other ones i used vice grips. and ill just go and buy some new bolts. i just gotta figure out what size they are..
thanks
Old Dec 10, 2002 | 08:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you could have bought the bit for less than the screws at autozone or a similar store
Old Dec 10, 2002 | 09:00 PM
breathment's Avatar
i don't think autozone has the special tamper proof torx bits..
Old Dec 10, 2002 | 10:12 PM
Black88GTA's Avatar
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
We have the tamper proof bit set at Advance Auto...IIRC, it's like $8.99 for a set of I think 8 tamper proof torx bits, an adapter, and a lil rubber boot thing to hold em all. That's what I used to remove mine. The thing that sux about them though, is that the hole in the center tends to weaken the bits quite a bit and they twist up with any kind of torque applied to them at all.
Old Dec 10, 2002 | 10:24 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I removed mine by putting the torx bit in place and tapping it with a hammer which flattened the bump down enough for the torx bit to go deep enough.
Old Dec 10, 2002 | 10:34 PM
breathment's Avatar
ya. i couldn't find my T-10 socket, only my T-10 i could find was my set of 90* torx wrenches. which aren't that big and i tried to hammer them down.. i guess i should of had more patience.. oh well as long as i can find some #6-40 screws then it won't be a problem. but my luck hasn't been the best so far..
oh and Black88GTA, thanks for the tip, ill have to go check and see if any of my local shops have any, it not then im sure snap on will.. its always nice to have cool new tools!
Old Dec 11, 2002 | 12:28 AM
Ed Maher's Avatar
Car: 04 GTO
I'm pretty sure i looked in at least 2 of the larger auto parts stores around here and they didn't have 'em. I admit it's rough, and not the greatest idea, but sometimes in the end it really didn't matter.
Old Dec 11, 2002 | 03:35 AM
rezinn's Avatar
I'd be careful with those tiny screws. Kragen carries the bits in socal. I got one with my afpr from summit, though.
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
Strick1
Sep 4, 2015 07:11 AM
