Looking For Seat Bolt Type Name & A Source
Old Jul 8, 2024 | 11:38 AM
Bohemian's Avatar
i need four seat bolts - M8X1.25x30mm wtf are these pointed seat bolts called?
These hold the seat tracks to the seat frame, then the seat tracks fit over studs in the floorpan and are held down with flange nuts.
I know it's some kind of flange bolt but I seem to remember these pointed body type bolts that I usually see in floor boards & fenders on gm vehicles are a specific type of fastener. These are also hardened, like grade 8 or better. Not a hardware store or auto parts store item.
Also I can't seem to narrow my search results down enough on hawks to find it without browsing through over 2000 hits on their site search results for seat bolts, etc.
So a source would be helpful as well.
thanks in advance.
Old Jul 10, 2024 | 02:57 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Looking For Seat Bolt Type Name & A Source
that type of bolt is called a flange bolt. No idea on what the pointed style is called, but you may not find those and will have to settle for non-pointed. It's pretty irrelevant once they're installed anyway.
If you do a search for M8X1.25x30mm black oxide flange bolt, you should find plenty of options... without the point.
Old Jul 15, 2024 | 09:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I'm sure I have a few of them PM if interested
Old Aug 13, 2024 | 02:01 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
McMaster Carr is your friend:
https://www.mcmaster.com/products/fl...x-head-screws/
njtta150
Oct 20, 2021 09:01 PM
58mark
Fabrication
59
Dec 2, 2020 12:33 PM
lopezisgod
Interior Parts Wanted
Jan 4, 2010 11:01 AM
Quick-IROCZ
Jan 21, 2006 05:40 PM
89IRO
Oct 21, 2002 05:56 PM
