New latch wont hold the door
Car: 1986 Chevrolet Camaro Sport Coupe
Engine: 6.0 LQ9, Truck Norris Cam
Transmission: 4L65E Z Pak clutches, Corvette Serv
Hello everyone! Sorry if it's a dumb question, but I had a problem with a door latch mechanism where it wouldn't lock/unlock the passenger side door with a key. So I decided to replace the entire assembly with a brand new one from amazon. Now it will lock/unlock and everything works. However it doesn't seem to hold the door in place very well. Basically when I push it from the inside or pull it from the outside the door moves about half an inch and is only then being stopped by the mechanism. Did anyone have a similar problem with an aftermarket assembly? Should I return it and try fixing the old one or is it something else that may cause this?
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: New latch wont hold the door
Well hello to you. Another member had so much trouble with his latch from Amazon that he gave up. He finally fixed it with a latch from Dorman I believe. Good luck and keep us updated.
Car: 85 Iron Duke, 88 GTA and 92 TA
The amazon part is junk, like 95% of aftermarket stuff for our cars. Get a good used original latch.
I still don't get how the manufacturers were able to build parts that last 30+ years in the 80s and now they aren't even able to just COPY a dumb part correctly. I mean, all the effort it takes to copy a part, get machines and material and all that stuff and the you can't even use it. Smh...
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Good used OE latches unfortunately have the plastic worn off. I bought these 9 years ago and they're still going strong.
https://www.ebay.com/itm/13303849806...QAAOSwEGxhL-Z~
Nevermind the year range. I had them first on my 84, now on my 89. Fit is the same.
Thank you for the reply! Yeah, I took it off and compared it to the original latch. It seems way more flimsy than the original.
3oh3 Cruiser
Dec 13, 2009 01:25 AM
