Climate control box
Climate control box
Got my car with dash completely disassembled and reinstalling the climate control box now and need to know where the vacuum hoses route. I have an assembly manual but it is for an 86 and the color codes on the vacuum lines are different than on the 88 apparently.
Where it calls for a yellow vacuum line mine has a brown one but I need to know if the other locations are correct please
Last edited by Noble1; Feb 18, 2025 at 09:53 AM. Reason: Pic wouldn't load/poor spelling
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Climate control box
The diagram that you've posted (Post #2) shows an 84-86 Berlinetta Heater core box. The Heater core box for a "regular" Camaro will be different because it doesn't have a Vacuum Solenoid or the HIGH speed Blower relay as shown in your diagram. ( I'm guessing the vacuum hose colors might be different too.)
Your diagram in Post #3 looks to be correct for the "regular" Camaro / Firebird.
