Center Console Issue
Has anyone had the issue with the upper part of the center console hitting the back of the parking brake? My camaro is a 92 and didn't have the upper part of the console. I got one from an 84.
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Re: Center Console Issue
Is this when you pull the brake handle, or just trying to get the cover installed? If when pulling the brake handle, they can be adjusted so that you're not having to go 90-deg. to get the brake applied.
