Tips for fog light switch replacement? - 1986 Iroc
Car: Yellow Gold 1986 IROC-Z
Engine: LG4 305
I've got a replacement fog light switch but I'm wondering how to remove the headlight switch so that I can get the panel all of the way off. I don't want to pull too hard and break that.
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Tips for fog light switch replacement? - 1986 Iroc
There is actually a button on the headlight switch body that you push to release the stalk. It is a pain to get to, either take the gauge cluster out, or remove the dash pad, or stick your hand up there and find the switch button and push.
Car: 89 Iroc Convertible
It’s easier to just remove the headlight ****.Its held on by a clip.I use a thin flat blade screwdriver to pop it off.
