Blower motor ground?
Car: '87 firebird
Engine: 350(?)
Transmission: 700-R4
Axle/Gears: 7.625 3.23
My blower motor ground is cut and tied directly into a ground on the firewall. The not factory setup doesn't work but I cannot find where exactly it should be grounded to. If I stick a wire from the negative side of the battery onto the tab for the ground wire on the blower motor it works so it's gotta be that right?
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Re: Blower motor ground?
If it doesn't work with a chassis ground, but works by going directly to the battery you've got a bigger problem. Check your motor to chassis ground, because just the weenie wire from the battery isn't gonna cut it.
Car: V8s
Engine: V8s
Transmission: Whichever ones deflect bullets
Axle/Gears: You can never get that smell out
That grounding point you mentioned any good?
edit: I mean ^ditto^
Last edited by Screaminchickun; May 22, 2025 at 08:17 AM. Reason: Beat to the punch
TransAMan
Nov 22, 2000 01:33 PM
