Cupholders
Old Sep 29, 2025 | 01:57 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Axle/Gears: Ford 9"moser 31 spline 350 gears
Cupholders
I decided to build me some cupholders for the Iroc , didn't really see anything out there that i liked, saw these on ebay and decided to give it a shot.. now there not perfect, but for me they will work just fine.
Old Feb 22, 2026 | 03:35 PM
Anothercarguy's Avatar
Car: 92 camaro
Transmission: Th350
Re: Cupholders
I actually like that as it almost looks as good if it could be stock and lines up perfectly. What key words did you have use when searching as I just find double din for radio/coin holder replacement that doesn’t have smooth exterior. How did you screw/bolt in? Did it already have bolt mounts on top and you just lined up and drilled holes to add nut?
Old Feb 23, 2026 | 07:41 AM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Re: Cupholders
Saw a vid on YouTube a guy built one his turned out better. Mine i made from 1/8 MDF, superglue, hot glue, bed liner, and 4 small pan head bolts that i drilled through the top MDF and glued in.
Old Feb 23, 2026 | 12:09 PM
Car: 92 camaro
Transmission: Th350
Re: Cupholders
Thanks for the reply, I have found many videos and shorts on YouTube and most are to install into din cubby in dash of vehicles and the Camaro one has the right idea and location yet I think yours came out better with more of a stock look of how it should have come from the factory. I am going to search out built in cassette style at the salvage yards of vehicles I always pass by to see if they have the single din cup dual holders as I don’t need the coin tray option that’s universal on eBay and Amazon and going to attempt to fabricate one also. Thanks for showing your setup
Old Feb 23, 2026 | 05:03 PM
sodak's Avatar
Car: 1985 iroc
Engine: 416 ls3
Transmission: t65
Re: Cupholders
This is what i used. and the plans changed a little but this will get you started.
https://www.ebay.com/itm/40646434633...3ABFBMtqHhy5Fn
Big&BadGTA
Oct 5, 2021 06:21 PM
turd_gen
Feb 23, 2018 05:37 PM
yaj15
Apr 27, 2014 11:52 AM
79malbiu
May 29, 2007 10:32 PM
RSFreak
Pacific Northwest Region
Oct 30, 2001 04:18 PM
