[For Sale] Ported LS oil pump
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ported LS oil pump
I have a ported LS oil pump for sale. This is the later "LS6" style pump, which was the same as every other LS pump except for the early ones which are generally avoided. In any case, this is a used pump, but I completely disassembled it, checked all of the components for wear, checked spring pressure, ported the housing, and re-assembled with assembly lube. Unlike everybody else, I'm showing off my port work! After the pic showing the porting was taken, I did a bit more finish work to smooth it out some more, then thoroughly cleaned it in a parts washer prior to re-assembly.
$85 shipped.
$85 shipped.
Re: Ported LS oil pump
I'm open to offers...
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
