LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] Never used lt1 swap harness made by pocket
Old Dec 28, 2011 | 02:10 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
I have a harness for a lt1/t56 swap into a thirdgen. It has a fuse box, all wires and plugs are labeled. Plug any play. I'd like to get $200 obo out of it.
text me for a faster reply. 740-819-7601.
Old Dec 28, 2011 | 09:21 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Never used lt1 swap harness made by pocket
great price......
If I didn't just sell my swapped car, I'd snag it
Old Dec 29, 2011 | 07:46 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
How does this plug in? I have a 92 I'm swapping an lt1/t56 into. Is this just from the main connector to the engine/trans? Any special instructions involved?
I don't recognize the black box on the bottom left. Fuse box? So this replaces the entire wiring harness under the hood including the stock fusebox?
Lol lot of questions, but I'm def interested.
Old Dec 29, 2011 | 10:21 AM
1badeagle's Avatar
Engine: 370 LSX
It plugs into the firewall right at The brake booster. This harness replaces the entire engine harness. The harness is plug and play. Plug in everything, hook up the battery and everything should work including the gauges. The fuse box you see in the picture is for the things that your old motor doesn't have. Let me know if your interested.
Old Dec 29, 2011 | 04:25 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Kick ***, sounds great, my last question would be does the car run with the stock pcm, or would I have to re-program it?
Thanks for your help
Old Dec 29, 2011 | 11:48 PM
1badeagle's Avatar
Engine: 370 LSX
Uses the stock lt1 PCM. Just plugs into the harness. You will need to have your computer reflashed if you start modding though.
Old Dec 30, 2011 | 03:23 AM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Final question. Does it matter what year lt1 / t56 I get to use this harness? I was under the impression that the optispark unit had different connectors from 1992-1994 and 1995-1997 LT1s.
I also need to know if this is odb1 or 2.
Old Dec 30, 2011 | 05:08 AM
1badeagle's Avatar
Engine: 370 LSX
It works on any lt1. I'm guessing it's ob2?
Old Dec 30, 2011 | 07:15 PM
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Well here takes a look at this, it shows the differences between the years.
http://www.nookandtranny.com/Info_LT1.html
The two different optispark connectors
PM pocket, and see what interface it is, obd1 or obd2. I need to know.
Old Dec 30, 2011 | 07:25 PM
1badeagle's Avatar
Engine: 370 LSX
I'm 99.9% sure it has both.
Old Jan 1, 2012 | 10:16 AM
1badeagle's Avatar
Engine: 370 LSX
Sold!!!!!!
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
