[Wanted] lsx wire harness
Car: 1991 rs camaro
Engine: ls1
Axle/Gears: 10 bolt
lsx wire harness
Im looking for a wiring harness for a 98 ls1 and 4l60e id like one thats already modded to fit in a 85 iroc , but not necessary
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
Re: lsx wire harness
Hey man check out a guy named "Pocket" on here, he makes them plug and play for your conversion. I only wished I had found this before I did mine with a standalone harness then spliced in what else I needed. Took alot of time, and his are super clean...
https://www.thirdgen.org/forums/ltx-...w-3rd-gen.html
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Pocket is the way to go. You will spend more in harnesses, parts, and time than it will cost you to have him make you a brand spankin' new one.
