[For Sale] Lt1 parts. Garage cleanout
Fel pro timing cover set for 95 and up.
7c545956. $10
Fel pro conversion gskt set cs9966 $35
Melling oil pump 155hv with matching shaft and pickup $50
Delco oil level sensor 19112977 $15
Lunati timing set 92126 $75
Clevite standard size rod bearings. Cb-663hnk. $100 for all 8
King standard crank bearings. mb557sistdx. $10 for the set
Msd early style opti, new. $300
95 and up timing cover, used $50
Mahle piston rings. .030 over 41616cp $45
These are all new in box except the timing cover.
Scat stroker crank, cast $150
Also have a good block that was hot tanked, clearanced, bored and honed .030 over, cam bearings installed. $500.(will include crank with block for $500)
ls1>*
137
04-02-2011 10:47 PM
IrocZ85
02-16-2006 06:11 PM
