Which year LT1's should I avoid?
Old Jul 18, 2005 | 04:47 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Did a search, but LT1 brings up alot you see.
I'm looking for a LT1 to swap into my 89 GTA, cause the bird spun a bearing. BTW, just about everything off the top end is for sale, though the HSR and associated parts is spoken for already.
Which years and car models should i avoid? I know that with some B-body LT1's I can run into the baby LT1, which is bad. However, I'm not exactly too sure on which years and model b-body engines to avoid. I also know that only F-bodies and vettes got the aluminum heads but I figure I can probably get a cheaper deal and later swap aluminum heads on if I want.
Do the Iron LT1 heads support enough lift for me to drop a hot-cam in there? Or do I have to upgrade the springs. I have one laying in my garage and its begging to be put to use.
Old Jul 18, 2005 | 05:09 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Best year one to get is 95 IMHO, keyed vented opti vs splined non-vented unit in the 94 models. You'll have to swap the springs in either head with the hotcam. The 96 models were the start of OBDII and the 93 models were SD motors that you had to burn chips for to tune instead of programming the PCM directly.
Old Jul 18, 2005 | 05:22 PM
Got a lead on a motor.
LT1 out of a 96 Impala SS. All accesories and ECM. But no harness(its hacked up). Fairly low mileage, about 57k.
I know it has iron heads, but that doens't bother me.
$650, sound too good to be true?
Old Jul 18, 2005 | 06:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
650 is about reasonable, good deal if its got the trans too.
Old Jul 18, 2005 | 06:22 PM
No trans. :*(.
Any way to make the 96ecm tell the 700r4 to lock up? Or do I have to get a vacuum switch?
If I can, I'll buy a 4l60e and sell my 700r4, probably the better choice.
Old Jul 18, 2005 | 09:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Get a 4L60E, trying to get your newer pcm to work with the 700R4 is more trouble than its worth.
Old Jul 18, 2005 | 10:09 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Put a manual lock up switch on your 700R4.
Everything you need to know to do it is right here:
https://www.thirdgen.org/newdesign/t...ueswitch.shtml
Old Jul 18, 2005 | 10:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Good job, now get him a 50,000 ~ pulse per mile signal out of his stock 4000 pulse / mile sender.
Old Jul 18, 2005 | 11:18 PM
I'd rather swap to a 4L60E. Its not like the car has to be up in a weekend. I could spend months swapping it and not be bothered.
Old Jul 19, 2005 | 10:41 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Good plan.
I wouldnt really avoid any of the years so much as base what i'd pay on the year and model it came from. Any of them you can use a 94-95 pcm on just the same.
Old Jul 19, 2005 | 10:43 AM
Is it possible to use a 96 pcm from an impala? Or is it not worth the effort? Cause thats what I'm getting, the motor is out of a 96 Impala SS.
Old Jul 19, 2005 | 11:04 AM
Klortho's Avatar
Car: 1987 GTA
It will be harder to tune with the OBDII, if you look on some of the Impala boards, alot are doing OBDI conversions which alot favor because of the ease of tuning themselves, plus the cables and software are cheaper.
Old Jul 19, 2005 | 12:36 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
You can use it no problem, get it up and running with a $50 vats module to avoid tuning, however when you decide its time to do your own tuning the software for OBDII is about $500, whereas OBDI is about $100~, the $400 you save on software will surely help cover the $75~ you'll spend on an OBDI pcm, and thats not counting getting something for selling your OBDII pcm...
Old Jul 19, 2005 | 01:58 PM
Klortho's Avatar
Car: 1987 GTA
The Impy PCM's doesn't have VATS in them, so he'll even save 50 bucks on that as well.
Old Jul 19, 2005 | 03:02 PM
I have a hot-cam for it, but today when I was thinking about it I decided to just throw the motor in stock. Why give myself other headaches when I'm doing to have to deal with the wiring anyways. I can always throw a cam in it later when i get aluminum heads.
I'll have headers, and a full exhaust right off the bat becasue I have that right now in my GTA. Hooker 2055's and a SLP 2otL cat-back.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
midge54
Aug 29, 2015 09:51 PM
zayne0
Aug 24, 2015 07:22 PM
