LS1 with a 3rd gen v6 tach
Old Jul 28, 2005 | 01:03 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I was thinking about this b/c I'm ordering my tach converter box for my LS1 swap. My tach right now reads to 8k with a 5500 redline. I was thinking that the v6 cars had a higher redline (6000 or 6500) and a higher overall reading too. If that is the case, couldn't you just use one of those tachs and adjust the tach converter to make it work? I think it would be kinda cool. I guess it doesn't really matter anyways because I'll be shifting it at 6800 or so.
Old Jul 28, 2005 | 01:37 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The V6 tachs are 8k with a 6k redline. I just changed the face on mine to this, thought it was more appropriate for the LT1 and it's within a couple hundred RPM of what it's actually turning.
Old Jul 28, 2005 | 05:12 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Sweet. That looks like it will work out great! Too bad I can't find one with a 6500 or 7000 redline.
Old Jul 28, 2005 | 09:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
What kind of converter are you buying? If you get a Dakota Digital SGI-8, you can easily change it yourself, so that if later down the road you find a tach that you would rather have, you could change it, instead of having to order it that way. I too have thought about a V-6 tach since mine redlines at 5K. When I do this, I just change the DD box from a 8cyl output to a 6 cyl.
Old Jul 28, 2005 | 09:22 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I've got the SGI-8 for my speedo... I had it before because I used to run a 355TPI with a T56 and used it then. Now I'm buying a baker's electronic tach converter off ebay. $40... I paid the $10 extra so I could adjust it for any tach/cylinder combo I'd ever run. I did that because I'm going to run my stock v8 tach for now but probably a factory v6 tach when I can find one.
Old Jul 28, 2005 | 09:23 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Here it is....
http://cgi.ebay.com/ebaymotors/ws/e...sspagename=WD1V
Old Jul 28, 2005 | 09:39 PM
Klortho's Avatar
Car: 1987 GTA
Linky no worky
Old Jul 28, 2005 | 09:41 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Try that one... sorry!
Old Jul 29, 2005 | 09:07 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
OK, as long as its adjustable, then two thumbs up!
eightsixseven
Dec 16, 2024 01:50 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
88IROC350TPI
Mar 27, 2002 08:26 AM
jason86/2.8
Jan 16, 2001 11:10 PM
