Guages arne't working
Old Aug 2, 2005 | 11:19 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
and I can't figure out why.
91z28 with an 95 LT1 swapped in. I'm trying to finalize the wiring, and realized that after I had the PCM reprogrammed, that the only guage that works is the battery guage. I can see the Tach moving when the car cranks, but nothing while its running.
I'm lost as to what happened. Before I had the PCM reprogrammed, I had oil pressure and tach. All that was done was VATS delete and the EGR turned off.......
Checked the guage fuse and its good, even threw an ohm meter on it for good measure. Double checked the connections and they are correct and secure.
Motor runs smooth and strong, I just have no temp, oil pressure or tach readings to look at.
any suggestions?
might try to tap into the coil for a tach reference. We'll see how that works out
thanks
-jason
Old Aug 2, 2005 | 11:49 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well scratch all of that. I have a refernce at the wire on the plug that changes with the tps. Soooooo I have a in car wiring issue or a tach that suddenly died
I'll mess with it after I eat
Ghettobird52
Jul 5, 2024 11:18 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Fronzizzle
Aug 17, 2015 02:52 PM
