Using 4'th gen tank....
Old Aug 5, 2005 | 09:06 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
If i run the 4'th gen tank...Can I just take the in tank regulator off and run an Aermotive Regulator up front? I also want to use the quick connects on the tank...Does anyone know which lines out of the pump are the return and sending lines and what sizes they are for the quick disconnects to AN fittings? Pictures would be best....
I know this is a lot of questions...But has anyone run aftermarket fuel rails On a third gen?
Old Aug 5, 2005 | 11:51 AM
fattdaddy's Avatar
Car: 1992 Rs
Re: Using 4'th gen tank....
LOOK HERE!
Old Aug 5, 2005 | 12:43 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Let me reword this.........
CAN I run a 6AN sending line and 6AN return line from the tank to the front of the car and regulate it up there and take the in-tank regulator out? if so...I need to know the sizes of the compression--> AN fittins that I will need at the tank and on the rail?
Thanks,
P.S. Also thanks for the reply I got some usefull info out of that.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
