Do you even need Fuel Vapor Canister??
Old Aug 26, 2005 | 11:01 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I'm buying quick connect fittings from Performanceplumbing.com for the fuel rail and for the sending and return lines from the sending unit on my 4'th gen tank. My question is can I just take off the fuel vapor canister attatched to the tank and not even use it?
Also, does anyone have a drawing with the lines coming out of the sending unit labeled as to which are sending, return, vapor?
this would be very helpful.
Thanks,
25thredrs
Old Aug 27, 2005 | 10:42 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Nah you really dont need it. You could just let it release into the air. Its really not enviromentally friendly, but whatever.
Old Aug 28, 2005 | 11:02 PM
onebinky's Avatar
It's just an emmisions device. If you have testing in your area, you won't pass. If you do eliminate it, I'd recommend sealing the evap line and running a vented cap or installing a filter on the line to prevent road crap from getting in the tank.
Old Aug 29, 2005 | 10:53 AM
TexasLT1's Avatar
Car: '92 RS
there was a long rediculous discussion about this a while back and the possibility of explosion by deleting it
I had mine unplugged for 4 years.
Old Aug 29, 2005 | 02:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
LMFAO, I'd love to read that thread.
If your concerned about the air we breath or have emissions testing/inspection, you can use it. Otherwise, you can take it off, just seal everything off like said above.
Its been over 5 years since I took mine off......
Old Aug 29, 2005 | 03:27 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
never understood why letting fuel vapor vent into the air was a really large deal... just look at what planes do... dropping all that fuel right out into the air... jeez.. I haven't had mine hooked up to any of my thirdgens from the day i boght them.. and one is even missing it lol..
Old Aug 29, 2005 | 05:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Because HC (Hydrocarbons, gasoline vapor) and NOx (Oxides of Nitrogen) in the presence of sunlight form Smog.
Old Aug 29, 2005 | 09:42 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
Thanks for the help guys...Looks like i'll be getting rid of it.....Sorry In advance to people who think it's a bad idea.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
