Carb Intake Manifold for LT1 EGR
Old Sep 6, 2005 | 04:39 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Where can I get a carb'd intake manifold for a LT1 with EGR provisions?
Old Sep 7, 2005 | 06:17 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Not one made with EGR, the only carb intake is made by GMPP and this was really designed for pre-emissions cars. But putting a carb on an LT1 is about like putting a carb on an LS1, it's not really worth it since you still have the computer controlling everything else, and you can tweak out the fuel curve better with the PCM
Old Sep 7, 2005 | 07:49 AM
crrllmich's Avatar
Engine: L03, LS1
Well originaly what I had in mind is taking the Long Block and using TBI. The engine didn't come with the computer, harness, or the actualy LT1 intake assembly, but since no egr might have to take a different route. Thanks tho.
Old Sep 7, 2005 | 09:13 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I was under the impression that putting a carb on an LT1 was like putting a carb on any SBC. The computer would not be used. The intake has a provision for a distributor, so the opti wouldn't be used.
Old Sep 7, 2005 | 09:45 AM
crrllmich's Avatar
Engine: L03, LS1
Yes but LT1 heads have different mount positions for the intake manifold. So I basicaly was curious if they made a carb intake that had EGR specificaly for the LT1.
Old Sep 7, 2005 | 12:08 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I am aware of the difference in mounting holes. You may have to use an external EGR like the one offered by Scoggin-Dickey for the Vortec/TPI lower.
Old Sep 7, 2005 | 12:23 PM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Since it's technically illegal to put a carb on a street driven car that was fuel injected I think you would be hard pressed to find one that would retain something as silly as EGR. Although it's not technically illegal to put tbi on an lt1 I believe it should be. I'm contacting my congressman.
Old Sep 7, 2005 | 12:59 PM
crrllmich's Avatar
Engine: L03, LS1
And again someones downing TBI lol. My other engine I am building is a 450+ HP TBI .... so SHHH! lol
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
