lt-1 wiring harness identify???
Old Sep 11, 2005 | 05:07 PM
mrfbody's Avatar
supposedly, this engine is a 95 but on the harness and on the oilpan, i see what appears to be that oil change sensor in the side of the pan.
was't that a 96+ thing? any tips or tricks for me to differentiate what year this setup is? engine and/or harness????
also i have a 95 computer, if the harness is a 96 will it work on a 95 ecm?
Old Sep 11, 2005 | 05:19 PM
ssean92's Avatar
Car: sold
the sesor on the side of the oil pan is the leval sensor. and my 95 has it so its not a 96 thing, i dont think a 95 harness will work with a 96, one is obd1 and the othere is obdII
Old Sep 11, 2005 | 05:48 PM
mrfbody's Avatar
sweet, that makes me feel a little better then. any way to tell the year of the engine?
where do lt-1s have the block casting numbers? can you find out what year it is like that?
Old Sep 12, 2005 | 09:26 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
My 94 also has that sensor. The engines and harnesses can be mixed and matched. The 96 will have a crank sensor that obd1 cars didn't have. I think the 96 also has 2 knock sensors. 96 will also have 2 extra O2 sensors. My casting numbers are behind the drivers side head before the transmission.
Old Sep 12, 2005 | 05:48 PM
mrfbody's Avatar
dooh. i forgot all about the post cat o2 sensors on obd2.
it is obd1 then. but strangely it does have 2 knock sensors. and 2 o2 sensors but no post cat o2 sensors.
thanx a bunch. i appreciate it.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
