The motor went....
Old Sep 23, 2005 | 08:33 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The motor went....
BOOM....j/k. Apparently I blew a rear main seal out and ended up spinning the #5 rod bearing, no biggie. My machinist said it will turn with no problems. Going to build it up a bit, have a buddy with a CC306 I'm going to put in the car, that with some mildly ported heads and the 3.70 gears should make the car move pretty good (like it didn't before ) Guess we'll see in a couple of weeks when I get the block/crank/pistons/heads back.
It wasn't bad at all either for parts, entire rebuild kit, with new oil pump, timing set, gaskets, bearings, rings, and freeze plugs was 384.00 plus his labor, total I'll probaly have about 900 after I'm done with it with the cam and new valve springs.
Old Sep 30, 2005 | 02:26 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Sorry to hear that... but now it just gives you the opportunity to beef it up some more. Good luck with everything though.
Jay
Old Oct 8, 2005 | 07:20 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
Re: The motor went....
that makes absolutely no sense. you wont starve engine bearings because of a leaking rear main seal, unless of course you fail to check your oil level more than once a year. even so, the #5 normally shouldnt be the first bearing to go, it should be the #1/#2. i would venture to say you've got bigger problems with the engine.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
