looking for picture of the lt intake throttle hook up
Old Jan 2, 2006 | 08:23 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
looking for a side view of the throttle cable hook up on the 94+lt1 intake. thanks
Old Jan 2, 2006 | 11:07 PM
Firebat's Avatar
are you running the 700r4 with the LT1? If so, you'll need a 93 throttle valve (TV) cable also. And a 93 TB and 93 TB bracket. The throttle (or accelerator) cable will be the same for 93-97 LT1's. I have pics of the 93(700r4) setup on my 95 LT1, would you want to see them? If not, i can try to get pics of my brother's 95 LT1.
Make sure you use a tpi accelerator cable (i used a 92). Or if you use 4th gen LT1 pedals, use a 93-97 LT1 accelerator cable.
go to this thread on more info on how to install the accelerator cable: https://www.thirdgen.org/techbb2/sho...hreadid=337001
Old Jan 2, 2006 | 11:40 PM
Firebat's Avatar
found a pic online, this would be for the 94-97 lt1 setup. Pic taken from a 95 Vette LT1.
Old Jan 3, 2006 | 12:46 PM
Firebat's Avatar
here is the 93 setup from my LT1/700R4
Attached Thumbnails looking for picture of the lt intake throttle hook up-20051227-005222.jpg
92camaroJoe
Jul 29, 2023 07:57 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
