Fule pump for Lt1
Old Jan 4, 2006 | 03:51 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Fule pump for Lt1
Getting ready to put a fule pump in and I was going to go with the tpi pump. But it might be awhile till I put the LT1 in. So my ? is if i go ahead and put it in will i have any problems while i still have the tb motor in it?
Old Jan 4, 2006 | 11:19 PM
TexasLT1's Avatar
Car: '92 RS
I'd wait until you start the swap. I'm not sure if the stock TBI fuel pressure regulator would handle a high pressure fuel pump.
Old Jan 5, 2006 | 04:49 PM
Car: 1992 camaro
Axle/Gears: 3:73
Ok thanks, one more question is the tpi pump the best one to go with or a aftermarket?
Old Jan 5, 2006 | 06:43 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If you have to change the pump, go ahead and get a Walbro 255lph pump. I used to know the part number, but have forgotten it.
Old Jan 5, 2006 | 10:10 PM
TexasLT1's Avatar
Car: '92 RS
what he said. if you're dropping the pump, put in a Walbro and be done with it.
Old Jan 6, 2006 | 06:12 PM
Car: 1992 camaro
Axle/Gears: 3:73
ok where can I get one?
Old Jan 9, 2006 | 03:31 PM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
http://www.treperformance.com/FuelPu...FuelPumps.html
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
