LT1 issue...
Old Feb 13, 2006 | 06:26 PM
Shagwell's Avatar
Car: projects.......
LT1 issue...
A buddy of mine is working on an 95 LT1. He just freshend the motor due to a rod-knock. After the new motor, it won't run w/ the MAF plugged in. It ran fine before and it runs fine w/o the MAF(should be in LIMP). He's checked all grounds, and checked to make sure he didn't pinch any wires. It's not throwing any codes on a Snap-On scanner. w/ the MAF plugged in it fire and die, but thats all. He said he can start it, un-plugged, and it will run fine, but if he plugs the MAF in it'll die within seconds. I don't know to much about the LT1.
...any ideas?
Old Feb 13, 2006 | 06:27 PM
Shagwell's Avatar
also, vac is around 30hg, timing has been checked,(even tore down to opti-crap and re-set/checked dist) and fuel pressure is good. He said maf wires have the 12-volt, gnd, and 5-volt. what gives???
Old Feb 14, 2006 | 12:27 AM
Firebat's Avatar
try swapping the MAF with one from another LT1, if you can.
Old Feb 14, 2006 | 09:00 AM
Shagwell's Avatar
tried a new one today, same results....
Old Feb 14, 2006 | 09:02 AM
Shagwell's Avatar
could it be the TPS setting? maybe cfm(maf) reading is high compared to TPS reading and the computer is outta whack? - it wasn't changed, but we're at a loss. I don't know enough about the LT1.
Old Feb 14, 2006 | 02:10 PM
Firebat's Avatar
nevermind
Old Feb 14, 2006 | 06:41 PM
Shagwell's Avatar
tps voltage is in spec w/ the book.
anyone???
Old Feb 14, 2006 | 06:51 PM
Firebat's Avatar
check out your map sensor, and really look at the map sensor connector...
Old Feb 14, 2006 | 06:56 PM
Firebat's Avatar
Also check out the IAT sensor
http://shbox.com/1/harness.htm
Old Feb 14, 2006 | 07:33 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
My money is on the wires going to the MAF plug. I had one once with the exact same symptoms. Turned out that one of the wires was broken right at the MAF plug, you couldnt see it unless you were specifically looking for it. IIRC, it was broken inside the coating too so it didn't look broken. I had to remove the pins from the plug, resolder the wires, and reinstall into the plug.
Also, runnung without the MAF connected will not put it in limp mode, it just runs as a speed density system(like the TPI and '92-'93 LT1 motors). You might get an off idle stumble and will have worse gas milage, but it will still be perfectly drivable. If your going to have your PCM flashed anyway, you could have it converted to a full time speed density system.
Old Feb 15, 2006 | 11:24 AM
Shagwell's Avatar
thanks for the responses. I'll be over at his place tonight, so we'll try that and I'll post back tomorrow.
- is a 92 TPI Map the same???I've got one I could try...
Old Feb 16, 2006 | 08:25 AM
Shagwell's Avatar
...I guess somtimes it just takes a fresh set of eyes. - He had forgot the silencer tube off the bottom of the inlet elbow.
Thanks for all the help.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
