wiring an LSI IAC
Old Mar 14, 2006 | 08:47 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
wiring an LSI IAC
I have a throttle body for my single plane conversion that uses an LS1 style IAC valve. It uses four pins as the TPI style IAC did, I am wanting to know how to wire it, what wire is what? Any ideas?
Old Mar 14, 2006 | 08:09 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
In 2000, it was:
Pin A, LT GRN/BLK, VALVE COIL B SIGNAL LOW
Pin B, LT GRN/WHT, VALVE COIL B SIGNAL HIGH
Pin C, LT BLU/BLK, VALVE COIL A SIGNAL LOW
Pin D, LT BLU/WHT, VALVE COIL A SIGNAL HIGH
1992 TPI colors are the same.
Kevin D.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
