Oil pan change
Old Mar 29, 2006 | 07:55 AM
NorySS's Avatar
Car: 1990 Camaro RS
Oil pan change
I can now confirm that teh truck pan is to low for use on an f body.
now what i need to know is. i got an f body pan. i take it bolts right up, is that all i will chnage or will i need a different oil pump pick up?
Old Mar 30, 2006 | 12:36 AM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
You shouldn't need a new pickup. If you do, it's only $15 or so at any parts store. If you do replace it, make sure you either weld it to the pump or make a bracket that bolts on so it doesn't work it's self out.
Old Mar 30, 2006 | 09:47 PM
beedo's Avatar
Car: 1986 IROC CAMARO
Axle/Gears: 3.73 posi
I think he is talking about a lsx motor, the pick up is in the rear and the pump is crank driven. Pick up tube is sealed with an o-ring so there isnt a way to weld it.
maroe624
Apr 16, 2017 08:29 AM
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
