differences between LS1 and LS2?
Old Apr 3, 2006 | 09:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Are there any major differences between a LS1 and LS2 swap? I know that the LS2 is consdered Gen IV, but will I run into anything not mentioned in an LS1 swap thread?
Old Apr 10, 2006 | 07:03 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
The only problem i could see is the drive by wire, but wouldnt be hard to convert to that, or to just run a cable set up. Maybe someone else can jump in here for you.
Old Apr 12, 2006 | 12:11 AM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Are the coil packs the same? Could I use ls2 coil packs on an Ls1? Is the wiring the same? And how about the hardware to mount them?
Old Apr 12, 2006 | 01:42 PM
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
Yes, you can use LS2 coil packs on an LS1, and vice versa. Pretty much everything is interchangeable between all of the LSx series engines.
I'm even running the LS1 wiring harness (modified by Speartech) with LS1 PCM, coil packs, LS6 intake, LS1 fuel rails and accessories, etc. Basically, an LS2 block with worked LQ9 heads, everything else came off from an LS1 I have.
That's what's great about these engines - except for the LS7, everything else interchanges easily. GM designed it that way. LS1, LS6, LS2, LQ4, LQ9 - they are all basically identical except for a few minor differences.
Old Apr 12, 2006 | 01:51 PM
Car: 1991 Camaro
yea the only other thing that might be different i can think of is the oil pan.
Old Apr 14, 2006 | 07:06 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
the whole front assembly of the ls2 is different being that the ls2 crankbolt is about 2 inches longer the whole cam , timing and front side of the motor is different, from what i know that is the main change
Old Apr 14, 2006 | 07:15 PM
While there are some changes in the OEM parts, you can still freely interchange LS1 and LS2 parts.
Beyond that, there still are no differences that one would have to worry about as far as swapping in an LS2 versus an LS1. If you are using a complete LS2 motor, just pretend it's an LS1 and you'll be all set, all the way up until you dyno tune it.
Old Apr 16, 2006 | 01:23 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
camsensor position is changed, injector fuel rails are different, LS2 injectors are .300 smaller than LS1's
Old Apr 16, 2006 | 10:14 PM
Kandied91z's Avatar
they are completely different animals with their own sets of issues.
both are very nice though and for the money ls1 is a gem.
Old Apr 17, 2006 | 03:04 AM
Car: 1991 Camaro
Yea the LS1 is still going to be the better one for the money just because of the fact theres more of them and they are older. But still when it comes to swaping them in they are going to be pretty much the same.
The sensors are a little different compared to a ls1 to a ls2 but thats only a issue when your converting your ls1 to a ls2(or more common a 402 ls2), but if you already have a a ls2 harness to begin with then that should by pass all those problems.
Speartech already does a ls2 conversion wireing harness so there goes the problem with the harness, then after that everything is basicly the same as doing a ls1 swap, except for the drive by wire problem. But you can run corvette pedals for that or just convert it to a throttle cable set up.
So in the end the ls2 is of course going to cost more compared to a ls1 just because the motor costs more, but when comparing what needs to be done to get one in, there isn't much difference.
Justin
Old Apr 21, 2006 | 08:08 PM
Justin
If you are building a custom longblock, the LS2 costs just about the same as the custom LS1 would. The LS1 is cheaper ONLY if you are getting a pullout motor and are doing a basic swap without modding the engine itself much.
In the end, the added cost of the LS2 is nearly negligible if you are doing more than just a stock engine swap, and installing it isn't going to present any problems the LS1 doesn't have.
Old Apr 23, 2006 | 11:20 AM
Car: 1991 Camaro
yes if your going custom long block then there would bacily be no price difference.
Justin
Old Dec 12, 2007 | 02:18 AM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Re: differences between LS1 and LS2?
I read somewhere the third gen radiator works great for Ls1 swaps, will it also work for the Ls2?
Old Dec 12, 2007 | 04:46 PM
GM-LSX's Avatar
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
What's up with the Cruise Control on the LS2 ?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
greenyone
Sep 2, 2015 03:39 PM
