lt1 fuel pump question
Old Apr 25, 2006 | 09:35 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Anyone every hear of this pump
eBay Motors: 255 LPH FUEL PUMP Chevy Camaro Corvette TransAm 255lph (item 8057634998 end time Apr-27-06 11:40:36 PDT)
Its pretty good price but not sure if its going to be ok.
What pump are you guys running on your lt1 swaps? Mine is still stock 3.1 v6 and while I have my rear out for rebuild im going to replace the fuel pump and paint the underside of the car to get it all done at once.
Old Apr 25, 2006 | 10:08 PM
Firebat's Avatar
I'm running a walbro. This one:
FULL THROTTLE SPEED - Kit Configuration Page
Old Apr 25, 2006 | 11:33 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Walbro 255lph here
Old Apr 26, 2006 | 02:02 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
sounds good thanks guys ill go with walbro
Old Apr 26, 2006 | 03:36 PM
TexasLT1's Avatar
Car: '92 RS
also a Walbro 255 here. good pump, no problems so far. bought it used too.
Old May 2, 2006 | 02:05 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
that's good to hear...i just got mine in today!!
Old May 2, 2006 | 03:32 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
how much did you guys pay for your pumps?? i found a new one for 110 shipped just wondering if thats a good deal?
Old May 2, 2006 | 05:35 PM
Firebat's Avatar
I think $100 shipped or $100 plus shipping. Can't remember. Bought it from the link I posted above but bought it off of them through ebay.
Old May 2, 2006 | 06:01 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
You can use your v6 pump as it's the same pump that's used on TPI v8 cars. I am using mine and have no problems, they say that the pumps is good up to 400 hp.
Old May 2, 2006 | 07:55 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
yea ive been using it but i think its starvig for fuel at upper rpms. seems like it leans out and i figure theres no better time since the tanks coming out for undercoating anyway.
Old May 2, 2006 | 08:51 PM
Klortho's Avatar
Car: 1987 GTA
Acutally the TPI pump and the 2.8 MPFI pump are different.
Old May 2, 2006 | 11:13 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I can get one made from Carter at pep boys LT1 FUEL PUMP for 150.00 commercial account =)
Old May 3, 2006 | 11:15 AM
That would explain why my car seems like it isn't getting fuel or voltage at high rpms. I personally thought it was voltage, but now I know. Crap! Now I have to drop the tank eventually to replace it.
Is it possible to install an external pump so that I don't have to take the tank out, or is that not an option?
Old May 3, 2006 | 11:39 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i would say thats not an option because then your unused stock pump will just get in the way of the flow. plus external pumps for high pressure are more expensive and dont last as long. ill post some pics of my tank removal today to help you when you do your. Im pulling it hopefully today but not installing the pump for a while.
Old May 3, 2006 | 05:06 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
ok i got it out pretty much the hardest part was fighting with it because it was hitting the shocks. my advice is to raise the car high as hell unbolt the shocks and let the rear fall as far as possible. unhook the usual stuff like brake line and fuel lines. To drain mine i just un hooked the return and rigged the relay to run constant that way i just filled a jug with the old gas with no mess. theres a pic of the old pump sock its really brittle and just fell apart.
A few pics. first is the bolt that i took out its really easy just 2 bolts. second is somthing that looks like a leak.
third?? What is that thing that hooks to the top of the pump?? Is it needed?
Attached Thumbnails lt1 fuel pump question-dsc00286.jpg   lt1 fuel pump question-dsc00288.jpg   lt1 fuel pump question-dsc00297.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
