LT1 SWAP UNDER FINAL CONSIDERATION
Old May 2, 2006 | 02:03 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
My 305 TBI took a dump today sounds like a vw beetle engine. I am now on a full on search for a LT1 with wiring harness and computer. All I need to ask from you fine folks are 1 thing and one thing only. I would very much appreciate the help if you could name what parts I will be needing and are nessassery for my new LT1 swap. Im planning on doing this myself and help of a friend.
Items needed for LT1 SWAP:
Motor Mounts?
Fuel Pump?
Shocks and Springs?
Radiator?
Steering Box?
Thanks eveyrone!!
Old May 2, 2006 | 09:18 AM
TexasLT1's Avatar
Car: '92 RS
Use your motor mounts.
You'll need at minimum a TPI fuel pump. might as well swap to a Walbro
Keep your stock ones.
Can use your stock one, upgrade to dual fans though.
Stock.
Old May 2, 2006 | 11:00 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
got it!! TODAY had to take out all my savings
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
midge54
Jan 29, 2017 07:00 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
sreZ28
Aug 14, 2015 07:48 PM
