LT1 BOUGHT!!! FINALLY!
Old May 2, 2006 | 10:58 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Got a used LT1 ENGINE TODAY!!! YEEEEEEEEEEEEEEEEEEEAAAAAAAAAAHH!! F********************CK Yeah!!!!! finally! got it for $1,100.00 from a place in Orange County,CA Stanton (562) 367-5050. Some Kat named, Dave
sold me the LT1 he don't know what it came out of. But the Engine comes complete with WIREHARNESS/COMPUTER. Nope not Aluminum Heads..... but I need to do this swap fast as I need my camaro running right away. Im going to have it delivered to my work Pep Boys.
So excited EEEEEEEEEEEEEEE!
Old May 3, 2006 | 11:43 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
she arrived today!!!! eeeeee had to load it on to the silverado with about 4 pallets!!!!!! it was hard as hell to get this off but we did it!!
found out what it came out of... 1995 IMPALA SS
Last edited by Psycho_91Camaro; May 3, 2006 at 11:44 PM. Reason: Automerged Doublepost
Old May 4, 2006 | 06:46 AM
net_coma's Avatar
Don't worry much about the iron heads. Some of the reading I did when I was looking for an lt1 indicated that the heads may flow a little better than the aluminum fbody heads. Fbody heads are a little higher compression to compensate for the cooling of the aluminum. Congradulations on ending your treasure hunt.
Old May 4, 2006 | 06:47 AM
cactusjack0053's Avatar
Car: 97 camaro
Engine: 3.8
Transmission: auto
let me know how t turns out, that's the same car mine came from and i might put it in my IROC. i just don't know if it's worth it
Old May 4, 2006 | 10:18 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
why would it not be worth it?
Old May 5, 2006 | 01:02 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Well Finally got the engine on the engine stand, and I gotta say it aint holding up well I think I used the wrong bolt size and they looked kinda short oh well they were the longest I had so I used em and I bent the front wheel of the engine stand ahaha ehh.. I Put a block of wood under the engine stand fram to support it and added a long block of wood and set it under the engine (oil pan) and ground to help support the engine, My g/f came over and she helped me clean my engine until she had to go home which was like at 10:30 pm she loves me like that here some pics! of the early stages before the engine swap stage! stages!!!!
The Impala SS 1995 computer
I don't know if this was suppose to be cut during the removal of the LT1 ? its the rear part of the engine wire harness
Here's the front of the engine wire harness, it is cut again I dont know if this was the right thing to do? or if it's something that just needs to be done during the removal process??? maybe someone could fill me on on this wire cutting deal?
Engine kinda polished the intake manifold...
Cleaned the engine as best as we could and where we could reach
Old May 5, 2006 | 01:03 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
ugh. it looks like they chopped off the relay/fuse center. So you've got your homework to do, if you re-use the harness. It's also the main body connection and the trans connection it looks like. I hate when people do that, to me its worse than denting a prize fender in. It takes an extra 20 minutes to do it right.
congrats on the engine though, You will have some work to do to get it all wired up. They run great BTW. Hop it up with a cam, and springs, and it will scoot.
Old May 5, 2006 | 11:32 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Thanks bro, Im currently bidding on a wireharness FAST FUEL AIR SPARK TECHNOLOGY on ebay
Im a little larry about reusing this wireharness so Im going to try to win this bid. I actually called like 7 Different Automotive Shops and most of them said they would not be able to do the swap because it was too time consuming, and one said they would have to take it to a refaree after the swap. Another said they never done it before but would do it? One shop called Waltons Automotive said they could do it but if it didnt run it wasnt there problem and that they would not warranty thier work!!???? One shop does LTX-LSX ect swaps called "pauls automotive" in Torrance,CA but they want $2500.00 just for labor, I told them I would provide all the parts.
I asked the service Manager at pep boys and he said he knows how to do it and would charge me about 600.00 for the swap but I would need to transport the camaro and LT1 to east L.A. where he lives.
Old May 12, 2006 | 09:53 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Save your money and just remove all the old power/fuse section out of the old one. Its should just unplug in various spots then remove it and you will be left with your engine harness. Next just visit the lt1 wiring for dummies thread spend a few hours wiring and your set.
Old May 13, 2006 | 08:11 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Or save yourself some money and find an engine harness from an F-body.
Old May 13, 2006 | 12:23 PM
net_coma's Avatar
For a harness, take a look on camaroz28.com. The are availabe there now and then. I have a 96 lt1 to install and was going to use an odbi and found a pcm and harness there.
Old May 17, 2006 | 02:02 AM
RAGEman's Avatar
Car: 87 Camaro Z28
Glad you found one. $1,100 seems a little bit steep tho. Oh well, you got one and you're happy.
Old May 17, 2006 | 09:26 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I think 1100 is average actualy. I paid 1700$ for mine but then again it was allot different and had goodies with it. Either way lt1's are sweet in 3rd gens!!!
Old May 17, 2006 | 02:13 PM
Klortho's Avatar
Car: 1987 GTA
$2800 for motor/tranny (6 speed) pedals, accessories, PCM, wiring, LT1 radiator/fan combo and underhood fuse box.
Old May 17, 2006 | 10:41 PM
RAGEman's Avatar
Car: 87 Camaro Z28
$1,100 for mine as well. LT1 with 6 speed, computer, harness, pedals,and clutch works. It had 96,000 on the clock when pulled.
Old May 17, 2006 | 10:47 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Well you stole that from whoever you got it from then.. lol
Old May 17, 2006 | 10:50 PM
RAGEman's Avatar
Car: 87 Camaro Z28
I guess so. lol. But as you said, LT1's are just sweet in our cars.
Old May 17, 2006 | 11:07 PM
RAGEman's Avatar
Car: 87 Camaro Z28
Some parts 4 sale - CamaroZ28.Com Message Board
I did'nt steal it officer, I swear!
I kid of course. He posted it at $1300, but I offered $1100 and he took it. I guess I just got lucky.
Edit: 99k, excuse me.
Old May 17, 2006 | 11:18 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
thats insane what was he thinking?
lol
Old May 27, 2006 | 09:35 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
Axle/Gears: 10bolt 3.23's I think
I was lucky enough to find a complete LT1 with harness for 500.00 has 99k on it though.. I think I'll pull the cam and heads and clean everything up, repaint, regasket and replace valve seals at a minimum, cam change will be necessary b4 I install it. And BTW it's ugly .. looks like it was never cleaned. Out of a Caprice Police car.
Old May 30, 2006 | 03:16 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
*LOL* Try two guys HAND moving a stock 305 with iron heads, out of a SUV and into a garage *LOL* now that is tough
Good luck with the swap.
Kinda glad I don't have a TPI or LT1, I'd probably supercharge it or just run to the junkyard and look for small turbos and do a twin turbo setup *LOL*
Old Jun 2, 2006 | 08:27 PM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
i gotta my LT1 for $300 iron head engine and harness out of a 83K totaled 95 police caprice and a set of aluminum heads and ECM out of a 95 Z, I got lucky and profited off my packrat buddy when he was moving
Old Jun 3, 2006 | 09:20 PM
88blkbird's Avatar
Car: 88 Firebird
Engine: 5.0 ltr
Transmission: 4L60
And I thought I got a great deal....
Old Jun 3, 2006 | 09:36 PM
1BADROC's Avatar
Car: 1989 IROC-Z
Axle/Gears: 9bolt 3.27
i paid 1900 for a 95 TA Lt1 6-speed was hit on passenger side was easily fixable but the guy didnt want to bother getting the salvaged title. Didnt even bend the frame. Im putting the motor in my 85 T/A i got the 6-speed in the 89 iroc and the seats and carpet is going in my 85. I might put the dash and console in but the console is missing 1 trim piece and i have a perfect console out of my 89 bird for the 85.
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
