show your LS1 Y-pipes
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Im tring to find an exhaust shop that will touch my car, and well its difficult! I would like some picture that im able to take to the exhaust shop of how other people routed thiers, and how well tucked up they are. It will be 3" piping, so if anyone has a good pictures of theirs it would help me out alot!
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
This is definitly something that hasnt been documented well from the people who have completed the swaps.
You could always print out the images from hawks..
Thats all I see on their site...
Hope it helps
Hope it helps
Car: 91 Z28
NP mang, I just remembered seeing the pics on Hawks when I purchased em, so I did a direct link to save ya some time....and possibly myself, who knows I might need to print this thread out when I take my car to an exhaust shop.
Looking at the picture though, I wonder why kind of ground clearence these cars have, look at the driver's side header pipe going to the Y has the pipe going around the Trans member and going across under the torque arm, and the seems like it would be a bad place for a low spot, especially around speed bumps....dunno, I guess I'll tackle that when I get to it
Car: 91 Z28
Originally Posted by Red92RS
as soon as my car is done I will get some pics, my spohn crossmember will have some minor surgery done to it for my exhaust to clear.
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
That's my car. And yes they had to trim the cross member to fit the exhaust. I wasn't happy about it, But it was clear there was no other way. My swap was done before the headers came out. Also it's a bit of a problem on speed bumps or steep driveways.
Car: 91 Z28
So you do have clearence problems, that sucks....maybe I'm gonna go with oval tubing...
Then again, I REALLY want the exaust to come out the sides right before the rear tires, doubt its possible though
Car: 91 Camaro
Engine: LO3 305 TBI
im finally getting around to taking pictures of mine completed. Its a 3" y-pipe, all mild steel with a Jet Hot coating on it. No CATs and 2 O2 bungs were put in.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I wish i didnt have emission test over here in cali
Must be nice not to have them. That why pipe is sharp looking by the way. Cant wait to see up on the car.
Must be nice not to have them. That why pipe is sharp looking by the way. Cant wait to see up on the car. Supreme Member
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
sure there is.
use a crossmember that has cutouts to clear the exhaust. theres were tons of pics of it on here before....
search for posts by my username containing the word "drews"
quick example:
https://www.thirdgen.org/forums/ltx-...ighlight=drews
Car: 91 Camaro
Engine: LO3 305 TBI
I have the drews crossmember, and the pipes slide nicely in the cutouts, once i get it on ill post up how well it looks.
Originally Posted by MrDude_1
sure there is.
quick example:
quick example:
Car: blue
sure there is.
quick example:
quick example:
Car: 91 Camaro Vert
Originally Posted by StevenK
I purchased my X-member before his was available. Does his work with the Spohn Adjustable Tq Arm?
no, its just a crossmember.
im running a torque arm that connects to a bracket i attached to the floorpan.. if you have a spohn crossmember already, and basic fab skills, it wouldnt be hard to adapt a copy of his mount to the drews crossmember, then re-enforce the crossmember...
or
make a bracket to attach to the floorpan, and connect the torque arm to it... this would be the route i would take.
Car: 91 Z28
I'm even more disapointed with the Spohn set up after today. I rolled the car out of the garage for the first time, and the right side hangs down so low it scraps the edge of the garage, looked like my car left blood cause of the red powdercoat on the concrete.
And if the exhaust is lower than that....holy hell, I'm gonna have to put monster truck springs in to get any ground clearance for daily driving.
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Here are some pics of the crossmember. Oh, almost forgot. I ran into a problem mounting the 02 sensor on the passenger side. Couldnt get it to screw in. I ended up having to pull the header back off and found there was welding bead blocking the passage. Wasnt happy having to pull the header back off but atleast it was a simple fix. I would have thought quality control would be better from stainless works...........jt
Car: 1984 Trans Am
Engine: 2002 LS1
Axle/Gears: 3:73
Here's mine. They used a small section of the SLP y-pipe at the end. I wish it was mandrel bent, otherwise they did a great job.
Car: Camaro
Engine: 6.2L
I used a Drews Crossmember and made my own. Much cleaner fit than the Hawks unit going around the frame. I managed to make the Collector the lowest part. No installed pics yet as I have only completed mock up engine is back out now but heres the y pipe on the floor. Full 304 Stainless
Car: 91 Z28
Originally Posted by tuske427
another pic
So have you driven this much? It looks like your pipe is laying on the frame rail and sitting slight lower than the X-member.
I dont have exhaust yet so I've been looking at how people are doing this. Problem is, I've already hit the X-Member getting out of the garage, so I was wondering if your having ground clearence problems
Car: 1984 Trans Am
Engine: 2002 LS1
Axle/Gears: 3:73
I have almost a thousand miles on it. Yes, I do hit things like speed bumps, so I need to plan my routes in the parking lots carefully. regular driving has been fine so far.
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Pics of my old setup (y-pipe, single catback) are in that link. I'm running the "drews double hump" T56 x-member. Its the only way to do it.
*Now I have the same SW Hawks LT's with the drews x-member, but I custom fabbed my own 2.5" all mandrel bent duals with an x-pipe, sweet thunder mufflers (old school chambered pipes) and tailpipes out the rear. I'll have to post pics and vids of it soon. I've got more ground clearance than a stock car...
The "drews" xmember is the hot ticket to any T56 swap with LT's and a nice y-pipe or duals
86White_T/A305
Sep 21, 2015 05:28 PM
dbrochard
Sep 19, 2015 08:13 PM
