LT1 wiring procedure
Old Aug 21, 2006 | 11:40 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
when you guys did your LT1 swaps, did you remove the wiring and ecm before putting in the engine, or did you leave it connected? if you did disconnect it, where did you start when wiring it up?
Old Aug 22, 2006 | 06:41 AM
ssean92's Avatar
Car: sold
all the engine harness can be removed. all the wires u need are at the bulk head connector
Old Aug 22, 2006 | 08:30 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
If your 2.8 is like mine, my harness was two pieces. One going to the ECM and the other going to the bulkhead connector. I pulled mine apart at the plug with the temp, oil and ac wiring next to the brake booster and used the rest that went to the starter.
specialized
Jun 18, 2022 09:26 AM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Aug 29, 2015 09:51 PM
